Battery Wiring Maintenance
Mainsail
1,886
Puget Sound, WA
I finally remembered to do this when it was daylight so I went out and measured everything and drew a picture.
A couple questions:
What gauge is the factory cable?
What gauge is recommended?
Cables are marked with 12O39293 WDD for the red, and 12O39267 WBQ for the black
frank8003
4,992
Ft. Lauderdale, Florida
Clean BOTH ENDS of any battery/alternator connection and make it all like when She was new.
I did, Yeah, I did work on many needed powerplant "golf carts" with all those connections and batteries.
Finally found the CDC stuff which resolved many issues. Really good stuff, not expensive
I did my Deuce One time and after never had any electical problems, Golly, one can weld with those batteries.
I also made facilities to firmly bolt down my batteries and it was all worth it.
If you wanna have real fun just the put the Deuce main ground connection back to NEW condition.
That one is UNDER the Deuce generator, go on, have fun with your truck, and put every connection back to new condition. I used new star washers even.
antennaclimber
1,191
State College, PA
I removed the engine out of my M1010 for a rebuild, when I removed the starter, I noticed the high current wire connection on the starter looked odd.
After removing the B+ wire from the starter, it appeared that at one time this connection became extremely hot.
Another example that high current connections need to be kept in perfect condition, one little flaw will lead to issues like this that will eventually fail.
antennaclimber
1,191
State College, PA
Once again it's that time of year to inspect your battery connections. It's no fun fixing them in the rain, snow and wind when it's cold and dark.
Check them on all your vehicles, not just the MV's. Check the battery connections on all of your generators, golf carts, race cars, Chick Magnets etc.
antennaclimber
1,191
State College, PA
Once again, the ugly battery connections are present on another truck. This is a M1008 that I purchased 4 years ago.
While changing the radiator (another disaster story) I noticed that the battery terminals were attached with the hammer method of crimping. Not being a fan of a ball peen crimper, I decided to clean up the connections and attach new lugs properly. Replaced the post terminal connectors and covers as well.
Fortunately for me, my occupation has the correct tools and materials to complete battery connections properly. Many of our customers have battery back up systems that require proper installation and maintenance.
One of the wires looks like it had water in it and showed corrosion (black) on the copper. So I replaced the entire piece of wire.
Cleaned up the bus bar and both sides of the terminals as well. Don't forget to clean the underside of your nuts before putting them back on the bus bar.
Cleaned up the battery posts as well.
Another reminder, it's the connections that you don't normally see that are the most important with high current connections. Simply looking at them is not a way to determine if they are good. Take the time to take apart your connections and inspect them for any defects. Minor amounts of corrosion with only get worse with time.
Remember to always practice safe working procedures when working with any batteries. Eye protection, covering of exposed terminals, insulated tools (if possible) and proper sequence of disconnecting and reconnecting. They are very unforgiving and will hurt you when you don't treat them with proper procedures.
Karl
20260216_173810.jpg20260216_174255.jpg20260216_174659.jpg20260216_174704.jpg20260216_190309.jpg20260216_190315.jpg
antennaclimber
1,191
State College, PA
Do you have a source or part number for the terminal at the starter end of the cable for the B+?
I looked for days trying to find the P/N for that special terminal. Could not locate one. I even made a trip to my alternator/starter re-builder, they didn't know of a source as well.
Sad thing is that I remember seeing one available a few weeks before and I could not remember what place had them.
deank
852
Inverness, Florida
I did find one source. It is on fleabay but the seller does not show the part number. About $33 bucks each plus shipping.
antennaclimber
1,191
State College, PA
I used a regular terminal and made sure that it was not going to cause any issues.
$33 each, I hope that included installation..
