DLippert
- 12
- 3
- Pittsburgh pa
Hi, my Humvee starts fine but it doesn’t seem to go on high idle when it’s cold (30 degrees) or below. I changed the temperature sensor on the rear of the motor. Also unplugged the solenoid and put 24v to it. It clicks and I notice a very little up tick in the idle. Is it possible that the solenoid is not working rite (wore out)? I also did push on the throttle peddle to set the idle. Did nothing. Any help would be appreciated thank you.
