timarr
- 1
- 18
- PT PLEASANT N.J./ MARTINSVILLE V.A.
GUYS, I purchased one piece Precision seals. Dont waste your time a pita! I found two piece precision seals #VWK1110 81 A OR VWR81. Its a perfect fit on my m1008 . Remove the window unit, drill out pivot rivit, remove bottom nut ,spring and washers, take out glass, drill out three rivits to remove vent frame from window rail, Sit down and push in seal into grove ,soapy water helps, put back together in reverse, install new pop riverts where you drilled and I used a 8-32 x 1/2 screw and locknut on pivot instead of a rivit. you can gett the right rivit and tool from LMC. Hope this helps ,its been a long search and I found on fleabay ,under 50 bucks for both sides shipping included.
