quantumspores
- 1
- 3
- Wake Forest, NC
Hi Folks,
I'm starting to build an audio system for the Vee (M998 ). This is the first time i've built an audio system for a 24V vehicle. Does the attached diagram make sense? Basically I was going to pull power off the ignition to a 24-12V transformer into the stereo and do a direct wire for the memory to a single battery (which should pull only 12V?). Then pull from both batteries to a 24-12V transformer into the amp.
I'm very open to suggestions on the best way to make this work!
Thanks Much
Thanks Much
