lawdog1623
- 1
- 0
- Texas
im gonna say it wasnt timed properly!
When you installed the IP, did you check any other timing indicators other than the crankshaft pulley?
You could have checked the scored disk under the little 4 bolt window or that the motor was TDC by pulling the front valve cover and seeing if the #1 cul valves were closed.
Just so we are on the same-page, you set the motor's crank to its LDT indicator and then pulled the original pump. Then you just bolted on the "üsed"pump? I am only asking so I know what all was done to install the 2nd pump.
The red scored tooth of the hydraulic head has nothing to do with timing the IP to the motor. Please don't bring that into the equation.
As long as the crank pulley is at the LDT mark(this IS a turbo motor, right?) is lined up, and the motor is at TDC(verified by the #1 cyl valves being closed). you should install the IP with the scored mark lined up with the pointer.
You know if you loosen the 3 outer bolts on the drive gear(of the IP), you can line up the scored mark with the pointer, with out turning the motor, right?
