Doghead Starter Mod Question
custm86
Kenosha, wisconsin
I'm switching my 86 M1009 over to 12v with three batteries, two specifically for the starting system. Will the relay mod from Doghead still be ok with a 12v system?
doghead
4 Star General /Moderator
1,196
NY
Why would you convert to 12v, but add a 3rd battery?
If you understand electricity enough to properly engineer/design your 12V, 3 battery conversion, then surely you can read the schematics and see what the relay does and make your own decision( or if you even need it).
CycleJay
Marietta, Ga
Doghead,
Just curious..
How do you wire up 2-3 12v batteries and still get 12v out of all of them?
Do you have to wire them in series or parallel? I do not remember.
Thank you, Good night,
CJ
CycleJay
Marietta, Ga
Hello Sparky,
Thank you for the answer.
So let me see if I get this right...
Series = More voltage = 12V
Parallel = More current = 24V
Do I have that right or wrong?
Thank you,
CJ
212sparky
Monroe/ Ohio
no
-Series : connect the positive from one battery to the Negative of the next will give you 24 volts same current (amps)
-Parallel : positive of one battery to positive of the next battery will keep you at 12 volts but double the current (Amps)
CycleJay
Marietta, Ga
Hi guys,
Thank you for the information.
I wanted to relearn how and why my M1009 got 24V out of two batteries..
I knew the concept, just was not sure which was which.
Good night,
CJ
custm86
Kenosha, wisconsin
There isn't much engineering involved in a 12v conversion. One alternator will run two batteries and the other alternator will run the third battery. run a few wires, change the starter to 12v. I by no means claim to be an electrical genius. Especially with relays. I understand the relay is triggered by 12v, and passes 24v when triggered. will it still pass 12v? (I'm assuming so) Or can it be just removed and bypassed? I have the Doghead mod done already (Thank You Doghead, Great Mod!) But I'm having some serious issues with the 24v starters I've recieved.
doghead
1,196
NY
You can eliminate it or keep it. Either way will work, after a 12v conversion.
Warthog
254
OKC, OK
If you must do a 12v conversion, PLEASE consider the Rosscommon Equipment Conversion.
It is well documented and allows future owners to easily restore the truck to stock in the future.
It also allows someone (us) to help troubleshoot any issues you might have in the future.
custm86
Kenosha, wisconsin
So i pretty much finished the conversion the Rosscommon way. My question is how does the third battery get its alternator charging? Do all three batteries still charge by both alternators at the same time?
custm86
Kenosha, wisconsin
So after working 16 hours a day average for two weeks, I finally finished the Rosscommon conversion. It works great so far. Al three batteries charge, and added two volt meters to the interior. one for the two starting system batteries and one for the accessory battery. All seems ok so far but still wary about driving more than ten miles from home after all the issues i've had before!!!:?
Thanks for the help and advice everyone!!:beer:
