Is there a spring inside the door somewhere to return the door handle to position so the door latches shut? I have to manually rotate the inside door handle or the door will fly open. I pulled the access cover off and lubed everything but it still doesnt return. It seems like there might be a small spring in the door handle mechanism that isnt working. I'll pull the other side off tomorrow to check, but I thought you guys could save me some troubleshooting.
Thanks.
Thanks.
