Driver Side Axle Boot
dbesade
Blachly, OR
Hello All,
I'm replacing Axle Boots and for the life of me I cannot get the Steering Arm off the Knuckle. I have gotten the Linkage off the Arm.. however using the TM information. Is there a trick I'm not getting :confused:
Thanks in Advance
-Dave
Phil Rhodes
Burlington NC
I'm not sure why you need to remove the arm but,,,,,,,,there are wedges on the four studs that hold the arm to the knuckle. The wedges are tapered and are split so that when the nuts are tightened the wedges are forced down around the studs and because of the taper the wedges get tighter as they are pressed down into the arm. Your best bet at loosening them is to strike the arm from the side. Direct pressure straight up seldom gets the job done.
dbesade
Blachly, OR
I suppose I could stretch the boot over it, however on the Passenger Side it was easier to get the installed on the Axle and then add the knuckle. I am also taking the opportunity to remove the knuckles and inspect the bushings and clean everything up. I got one of the cones out and have been smacking the arm at the side. They are pretty rusty.
-Regards,
Dave
sandcobra164
325
Leesburg, GA
Plate underneath is the kingpin bushing. Tap on the edges of the bushing with a chisel to try and pry it loose from the knuckle.
