blackhorse
- 2
- 3
- west palm beach/Fl
1951 Dodge PW M37
History of my problem:
Would run about 2 minutes and stop- found a burned out coil and replaced$160.00.
New coil lasted about 3 miles. Replaced Coil and condenser$180.00
Sent distributor and cap to supplier for diagnosis and rebuild. Installed new bushings,coil, cap rotor, points. wires OK-$400.00.
Installed ,ran for 5 miles and stopped. after a long cool down it will run a few miles and stop again.
Checked charging system and found it was putting out 32 volts back to batteries.Adjusted the Voltage regulator to 27 1/2 volts truck ran good for 30 miles and has stopped again.
When I say stopped I mean the engine sputters and has absolutely no power to hardly move and then only a few feet at a time and will shut down completely ,may start back up and sometime may not.
Running out of patience and money for this M37.
CAN ANYONE RELATE TO THIS PROBLEM AND PASS ON SOME USEFUL INFORMATION TO WHAT I MAY USE TO HAVE A RELIABLE VEHICLE FOR THE ROAD.
