FLU 419 Differential Bolt
INFChief
1,350
New York
Greetings,
Does anyone know the specs for the Differential case bolts and where I might get one ?
I cannot find the length, thread size, or pitch for the bolt. But going back Ft of what I found for the nut you should be able to remove a nut (and or bolt) to verify.
Bolt = NSN: 5306-01-242-0602. P/N: 914141012205.
Nut = NSN: 5310-01-259-3584. P/N: 000934014022.
The nut is a 14mm X 1.5 thread put her (fine). Grade 10.9.
DIN 934 M14X1.5 STL 10.9.
knowing that you can measure the bolt length or take one out to match it up and purchase one (or how many you need) with nuts.
