Pernal78
- 10
- 3
- Elizabeth, Colorado
Hello, I have a simple question. Should the front loader on the FLU419 be able to lift up the front end so the tired can be changed?
Thank you
Thank you
.Hello, I have a simple question. Should the front loader on the FLU419 be able to lift up the front end so the tired can be changed?
Thank you
Since it's a 1990, there is no warranty left! I was able to get the front end up with blocks!With the pressure relief setting as configured, the FLU is not capable of raising the front-end up. I have seen two options; One of them is to roll the bucket underneath with a combination of hydraulics and slight forward travel. The other option will void your warranty.
.Since it's a 1990, there is no warranty left! I was able to get the front end up with blocks!
Now with new tires on, I'm using her and scoop with the front bucket but it can't lift the weight. Is this a common problem?
Did ypu change anything such as the check valves or regulator?Mine lifts gravel just fine knock on wood
