Front winch removal and teardown
Mario
89
Rio Rancho, NM
@Mario
looking at the TMs i have, the driven side (driver side, drum lock and free spool/engage handle) or non powered side as you called it, TM 9-2320-260-34P-2 FIG 380 item # 7 P/N 10875107-7 NSN 5330-01-119-5801 and in the tm link you provided TM 9-2320-272-34P-2 FIG 387 item # 34 large seal, seems to be difficult to source, even with the FSN web link you provided. Big Mikes show to be sold out, but he has the small seal fig 380 item # 41 and fig 387, item # 31 small seal, which cross references to the FSN link you posted. Were you ever able to locate the driven side seal? Did you by chance take measurements of the seal?
This is the other, smaller seal on the left side by the gearbox.
Mario
89
Rio Rancho, NM
RandibFarm
Bloomfield, NY
I know this is years late but I just had to replace the big seal on the non-drive end of the winch. I found and used a SKF 58716 seal along with a SKF 99587 speedi sleeve, both from ebay. The OD of the seal is 7.125" which fit tightly in what was supposed to be a 7.113" hole. My drum was rusty so I added the speedi sleeve which was supposed to fit a 5.871" to 5.879" shaft and it fit nicely. Thanks to SteelSoldiers and this thread I found and download the parts books!
