- 629
- 24
- 18
- Port orchard, WA
Don't forget to seal up the hole in spindle, or you will find oil in more in wanted places.
You can keep the CTIS and run higher pressures by just adding more air in the tire can't you? Course you could always do as was discussed earlier in another thread and remove the CTIS computer and make it a manually adjustable pressure CTIS system... I'll likely remove my ctis as well to run higher psi in the tires.
2 questions: Where, exactly, are you making the measurement? Is the TM wrong, why isn't the axle nut torqued to ~400ft-lbs to seat the bearings & seals?...It took four tries to get the correct shims in but believe I got it correct. Had to use the Mexican micrometer to gage the size. LOL
I use High Tack gasket sealer on hub and end cap....
