signalcorps
- 232
- 43
- Longwood Fl
When installing the floor, do the side baskets go on first and the floor goes over the edge of the basket mount or does the floor go on first and the basket mounts go on over the floor?
Without an actual mount on hand, using existing reference photos and known thickness of the frame tubing at 1.5" OD, I would bet the sides are 2x2 in square tube: (I can't remember who HQ4 belongs to)Does anyone know the size of the square tube used to make the top weapon mount?
I am not sure I understand, are you asking rim width?How wide are the factory front wheels?
Most would have a number stamped into the main housing tube. or engraved. You may have to pull the shock then do max expansion and minimum collapsed length.Does anyone know the part number for front and rear Bilstein or other brand shocks?
