sail78385
- 202
- 38
- Charleston SC
.Broken manifold bolts -no problem
View attachment 937556View attachment 937557View attachment 937558View attachment 937559
.Dropped the fuel tank today, sheesh. If you ever wanted to know how NOT to drop the tank let me know -I’m an idiot.
Started off fine, disconnected the lines through the access panel.
removed driveshaft
Unfastened the hose between each tank side -for sloshing fuel???
removed fuel filler and vent tube
Then went to drop the tank…. And here’s where it went wrong.
I should have realized that 2 of the fuel hoses are connected to the heat shield on the forward part of the tank. Ok I fixed that.
went to drop tank and it almost came all the way out, but the damn brake rotor guard kept it from dropping all the way. And that’s about the time I realized the tank was completely full of fuel.
what a damn mess. Glad that’s over with, now to air out for a bit.
View attachment 937587View attachment 937588View attachment 937589View attachment 937590
That might explain why the heater crossover tube that runs through the doghouse is missing? Lots to learn thanks MogmanYour truck probably had a generator at one time or a heater that was diesel powered, one feed one return so they just looped them when they removed the equipment
I think that hose is just about always missing.That might explain why the heater crossover tube that runs through the doghouse is missing? Lots to learn thanks Mogman
I think you mean camberOk, getting ready for the body lift and wanted to see what a 42” would look like beforehand and there is plenty of room! I’ll probably have to trim the exhaust on driver side. However it looks like I’ve got a little bit of caster to adjust. I’ve got some shims on the upper control arm mount. Wondering if I can just loosen those bolts and knock them out and tighten it all back up without issue?
man this thing is going to be rad! Photos don’t capture the awesomeness real well. Plan is to have the lift installed, engine mounted and all 4 wheels and tires mounted up before February.
View attachment 937690View attachment 937691View attachment 937692
