I need to replace the fan clutch on my truck. This is a REV model with the extended snout and geared fan drive, so it is different than most.
I need to remove the radiator to get to the fan clutch., and I need to remove the Oil cooler to get to the radiator. The Oil cooler does engine Oil, transmission, and power steering . So after removing it, I then need to refill engine oil (no biggie) and transmission oil and power steering oil, then bleed the power steering system. The workload seems to snowball.
I'm wondering if anyone has unbolted the oil cooler from the Radiator and slid the radiator out, without disconnecting the oil cooler. I'm hoping that there's enough slack in the oil lines that I could suspend the cooler from the rafters of my garage.
PS - whats everyones go to engine oil in these things.
