panzerjunky
- 1
- 0
- san diego ca
Hey Fellas Hope all you east coast guys are keeping warm
I dropped a post a while back about smelling Coolant that has not gone away but now I think I have a larger issue.
I was low on coolant about a gallon and 1/4 But I have oil dripping in small amounts at the front of the engine showing up mostly on the bottom of the lower rad hose and alt mounts as well as the fan pulley and spraying on the hood inside in line with the fan.
and there is a little oil stain at the block to head joint right above the data plate on the block.
Due to coolant loss I am suspecting a head gasket leak How would one confirm this? Should I drain the oil and look for coolant?
here are some pics if more are needed just holler.
Thanks Jerry
Thanks Jerry
