rockyroad217
- 0
- 0
- Arkansas
I finally got the brakes working on the deuce today after replacing every wheel cylinder, repacking all the bearings (doesn't have to do with the brakes but since I was in there), replaced with a new master cylinder, and power bled them.
I have a few concerns/questions..
1) Is the airpack supposed to make any noise when you hit the brakes? My brakes are working fine, well as good as I know them to be, since they didn't work when I got it. The pedal goes about halfway to the floor and doesn't bottom out or anything, but no air noise from the airpack.
2) When I was driving it home, my brother was following me and said the rear most axle was bouncing up and down..What would cause axle hop? I had 5 14.00-20 tires in the bed, so it had a little weight back there. Is it because the tires just aren't balanced or something?
3) The low air buzzer only works at about 70 degrees or higher during the day..never at night or never on cold days..I thought maybe some wiring problem..but is there a pressure switch I should be looking for somewhere? ( I don't really care if that buzzer works or not, but just curious.)
4) My fuel tank is leaking where the fuel pump assembly is and at the fuel cap, where can I order those gaskets?
5) What is the usual amount of pedal used to maintain a speed? I was more or less on the floor coming home. I think the speedometer is wrong, it said around 40 but my brother said we were going around 48..The rpm's were around 2200 rpms and it was mostly flat highway.
Sorry for always making threads with a whole bunch of questions, but I know you all have a vast knowledge of these trucks. I'm just trying to learn everything I can about them. Thanks!
