bigfishtoys
- 6
- 8
- Madison, WI
I enjoy working with people who know what they're talking about. Thanks for all your helpful responses! Now i understand these previous posts talking about using these little bulbs. I've decided to try this bulb that Mjvaden used to solve what sounds to be the exact same issue as i'm having. I'm ordering these from superbrightleds.com: BA9S-W4-32-28VAC: BA9s LED Bulb - 4 LED - BA9s Retrofit - Cool White 32 Degree 28VOk I got the little led bulb for the turn signal and every thing functions properly now. The little led bulbs came from superbrightleds.com and was about $3. I replaced the gauge lights with the same led bulb as well. The bulb was a ba9s-x4.
Glad I got it figured out. Ended up a $3 fix instead of a $200 plus flasher unit fix.
I didn't see a 24v option, so i'm assuming 28v option is a suitable alternative. I called them, and they said the 28v should work as well. Here's the website link for this bulb in case anyone else needs it. Bulbs are $1.98 each. Shipping for up to 18 is $3.32 - not bad. Now i just need to figure out how many bulbs i'll need to cover my blinker arm, and all other dash lights. If i'm doing one, i might as well do them all.
https://www.superbrightleds.com/mor...a9s-led-bulb-4-led-ba9s-retrofit-lan/2538/49/
BA9S-W4-32-28VAC: BA9s LED Bulb - 4 LED - BA9s Retrofit - Cool White 32 Degree 28VBA9S-W4-32-28VAC: BA9s LED Bulb - 4 LED - BA9s Retrofit - Cool White 32 Degree 28V
