HMMWV Spindle Nut Socket dimensions
SarahJ
Bristol, England
Hi Guys,
I am going to make a Spindle Nut Socket, as they are hard to get and expensive with shipping ($60), English Taxes (20%) and Royal Mail handling charge ($10). Yes, another Tea Party would be nice :grin:
I've got most of the critical dimensions from measuring the Spindle Nuts, but need the depth inside the socket and also the depth of the prongs that engage the slots in the Spindle Nuts.
Many thanks,
Sarah
DatGuyC
22
Essex, Maryland
I bought a generic spindle nut socket, I think it was for Ford, and just had to grind off one of the nubs for it to work. It isn't as "secure" as the proper tool but for the 4 times I had to use it, it worked.
papakb
1,201
San Jose, Ca
Sarah,
I don't know where Warwick is in the UK but Jon did this same job a while back. Here's a link to his post: https://forums.g503.com/viewtopic.php?f=63&t=223659&p=1313374&hilit=hmmwv+spindle+nut#p1313374
Here's a link to Amazon UK that you might find helpful:
https://www.amazon.co.uk/Performanc...&sr=1-4-fkmr0&keywords=4pt+spindle+nut+wrench
When you know the correct size they may be able to help you.
Some additional information:
https://www.hummerpartsguy.com/Geared-Hub-Spindle-Nuts_b_3.html
SarahJ
Bristol, England
Hi Kurt,
Thanks for the links, had a bit of a break from my Humvee as I had a nasty Norovirus, yuck!. I fancied making the Spindle Nut Socket and finished a couple of days ago, photo below.
Started as a block of steel 60mm dia by 50mm long, nice little project :-o
privatevince
Germany
is this correct, the Performance Tool W1272 (for Toyota) will do the Job on the Humvee single and/or dual notch spindle nut?
in that linked Amazon page they also sell other Ford and GM spindle nut tools...
TOBASH
4,173
Brooklyn, NY
Doesn’t the $20 Dana 44 socket work with a little modification grinding off a little nub.
JoeATK
14
ATL Georgia
Looks like it would, although the frustration in using the tool might outweigh the benefit of the low price. I'm willing to take the chance...the next time I inspect the hubs, I'll have that socket handy.
