- 228
- 58
- 28
- Chesapeake, VA
Those drain holes are a great idea!And after you check and re-grease the ( solid ) trunnion bearing re install using two bearing nuts instead of just the one, and if you don't already have one then drill and install a grease fitting in the bearing housing ( see pic ) I also drilled drain holes in the bolt slots ( see pic )
Both of ya'll are bringing up very good points. I would say the majority of deuces out there are 40-50 years old and I have encountered several with severely corroded u-bolts. It's really kind of a terrible design, I guess when they did it they didn't think about it or they didn't care because they thought the trucks would have 20 year service lives instead of 50+.I will post this also in my other thread also. But I'm glad I removed my U Bolts to get to my upper torque rod nuts. Hidden inside where those drain holes was a U bolt that was severely rusted through to the point of failure. Something you can see until removed.
Are you planning to take the spring pack apart? I've been thinking about doing that.People might think I'm crazy. But I'm only removing spring to clean it up, paint, replace Bolts and lube everything up with antiseize for example. I'm already there. I might as well do it. My theory is to replace now, rather than being somewhere broke down with a part failure and not being able to service the truck because of frozen Bolts or worse sheared off Bolts.
I don't think it's crazy. There's no other way to paint leaf springs. You have to disassemble them and blast them to get the rust out from between the leaves. If you just sandblast the outside, the rust will creep back out in 6 months.People might think I'm crazy. But I'm only removing spring to clean it up, paint, replace Bolts and lube everything up with antiseize for example. I'm already there. I might as well do it. My theory is to replace now, rather than being somewhere broke down with a part failure and not being able to service the truck because of frozen Bolts or worse sheared off Bolts.
Exactly my problem. I painted mine but it's rusting back up since I couldn't get in the middle of the spring pack. Is there any trick to taking them apart or do you just break the bolts loose and then put new bolts in? Is all the other hardware reusable?I don't think it's crazy. There's no other way to paint leaf springs. You have to disassemble them and blast them to get the rust out from between the leaves. If you just sandblast the outside, the rust will creep back out in 6 months.
A lot of people say re-using u-bolts isn't a good idea. I'd re-use the rest of it.Exactly my problem. I painted mine but it's rusting back up since I couldn't get in the middle of the spring pack. Is there any trick to taking them apart or do you just break the bolts loose and then put new bolts in? Is all the other hardware reusable?
What are you going to do for paint? I heard there's a special paint/coating you're supposed to use to keep the springs from sticking together.Yes I'm taking them apart. Replacing spring center pin. You know dang on well that the center pin is rusted out too.
Actually it is a good design. It has held up for 50 years ! Most trucks don't last more then 15 years in active service. Even our buses which cost almost 1 million each only have a life span of 15 years. So considering these trucks have been driven and maintained by 18 year old men I think their doing pretty good !Both of ya'll are bringing up very good points. I would say the majority of deuces out there are 40-50 years old and I have encountered several with severely corroded u-bolts. It's really kind of a terrible design, I guess when they did it they didn't think about it or they didn't care because they thought the trucks would have 20 year service lives instead of 50+.
