Hoefler
- 21
- 38
- White Bear Lake,MN
When first start up with cool engine, no rattle. After engined hits 200 degrees, the rattle would start. Sounded like a metal heat guard on exhaust rattling. Looked every where but couldn't pin point it.
After enough head scratching, I finally determined that it must be the belts on power steer pump and or generator. Figured the belt were slipping so I picked up a bottle of belt dressing which helped for about ten minutes. At least it got me to the root of the problem.
While adjusting the power steer pump, I noticed it flexed out a bit which caused me to crawl under the truck only to discover the lower bolt that secures the pump bracket to engine was sheared off.
This left only the upper two bolts to hold the pump in alignment.
I took the pump with bracket off from below the truck. Tight fit but it will drop down if you unbolt the sway bar.
I simply drilled a hole through the broken boly and pounded a flat blade screw driver into the hole, backed out the fugitive threads (mine was a 1/2-UNC bolt). Picked up a grade 8 bolt 1 1/2" long with new lock washer and re-assembled.
Will tackle the bleed procedure in the morning.
Check your bolt on the bottom of this bracket-two on top and one easily seen by crawling under the vehicle.
Pete
Pete
