I was driving my M923A2 out of my driveway in 2nd gear and accidentally moved the gear shifter up.... all the way to Reverse.
I overshot gears 1 to 5, then past neutral...into Reverse.
The tires locked up on the pavement, the engine did NOT stall, and I then dropped it back to neutral and to forward gears.
Now the Allison Transmission sounds bad, does not go into gears higher than 1st or 2nd.
I stopped, & put it into Reverse and backed up the 5 ton for 30 yards, hoping that would back out the damage or locked gear, in case something in the trans is still wanting to go to Reverse.
That did not help.
Now when I idle & sit in neutral, the transmission bucks backwards into Reverse.
Also, when I am coasting down a hill in neutral, the transmission is NOT free flowing, it has lots of noise and drag, as if something in the transmission is holding it back....and the trans has a winding sound in neutral & the 5 ton gets slower and slower.
Please help.
I hope I did not destroy my trans.
I hope there is an easy fix.
That did not help.
Please help.
