Leaking tranny
deuceman51
15
Scotland South Dakota
just wondering if anyone else is/has had trouble with their drain plugs leaking? Is anyone using anything different than the copper gasket they normally use? I have mine tightened up pretty good and they are still leaking so i'm thinking about going to something else. My output shaft on the tranny is leaking pretty bad also. Anyone had any experience with that problem? Thanks.
butch atkins
Fountain Inn SC
nrver had problem with copper gaskets leaking,replace them and make sure surface where gasket goes is smooth and flat,are you sure vent line from tranny are not stopped up,while driving down road i decided to check tranny fluid,my buddy was driving, opened cover, removed dipstick
what a dumbass thing to do,30w oil spray everywhere,thats how i found out why my rear seal was leaking, the vent line had been mashed flat by previous owner tranny couldnt vent internal pressure,sure helps when you read the manual,if vent line is not stopped up maybe you need replace rear seal,good luck
Lance Corporal
Make a washer from pencil tablet backing or cereal box material. If you do so make a bunch while you're at it. Place between copper seal washer and pan. It's always worked for me. The reason for making a bunch is that you made need a new one each time you remove the plug.
