cattlerepairman
- 3,584
- 113
- NORTH (Canada)
Long weekend and getting fed up with having to back up with my 4-ways on. The ideal time to install backup lights.
I used 2 spare "lollipop light" brackets and mounted them upside down behind the rear composite lights. For lights I used small fog lights from a tractor supply place and sprayed them green.
Light switch: I used a tractor supply push-button starter switch with a nice round rubber bubble over the switch, removed the floor board, drilled a hole in the cross member behind the tranny so that the hole lines up with the rod sticking out at the rear of the tranny and mounted the switch through that hole in the cross member.
When in reverse, the rod sticks out the farthest, pushes the button and the lights go on. I hooked into the dash light circuit for power supply and wired the two 12V lights in series, so they run with the 24V supply. Works great and, IMHO, the lights look as if they belonged.
One done, I discovered a puking axle seal and got to do that one too...done it last year, but the RTV in the keyway seemed to have become dislodged.
My wife also painted the truck's name onto the hood..."Queen Lola" now has a name tag!
