Losing speed in 5th?
cbvet
21
Northwest (Knox) Indiana
Took several vehicles to the July 4th parade in LaPorte Indiana. Biggest audience we've EVER had!
On the way home, my non-turbo Deuce started losing top speed/rpm.
2Nd, 3rd, & 4th wound up to 2600 rpm just fine. But once I got into 5th, I couldn't go over 1900-2000 rpm.
About 200 miles since all fuel filters changed. Level ground, no load. Checked all hubs & drums & found none overly warm.
Too hot to work on it right now, but I'll have to soon.
Any ideas?
wreckerman893
Possum Connoisseur
15,649
2,178
Even though you have fresh filters doesn't mean that there was not water and crud in the tank that got sucked into them.
Whenever there is a loss of power like you describe the first suspect should be the fuel filters.
Other possibility could be air getting into the system thorugh a loose connection or hairline crack in a line.
Anytime I get a new deuce the first item of business is to completely drain the fuel tank and let it air dry.....then put a shopvac hose in and suck as much dried out crud as possible out.......you would be amazed at what you find in the bottom of a fuel tank in a 30 plus year old truck.
My best score was several dollars worth of quarters that had ended up in one....never did figure that one out since someone had to have pulled the strainer out to put them in.
1,831
I still have that turbo here Eric. Gimpy, haven't forgotten the LDS intake elbow, just have no time.
cbvet
21
Gimpy- Generally level ground.
Wreckerman- I thought filters first, but as I said they're recent. And truck ran fine the 1st 45 miles of this trip. I'll have to check them I guess.
By the way, there was a story in the news here lately, about a guy who blew up his car while using a shop vac to clean his gas tank. Have you & my wife been talking again? SH-T!
Recovery- I'll PM on turbo.
wreckerman893
Possum Connoisseur
15,649
2,178
Well......I always make sure the tank is free of liquid and has aired out for a day or two.
Yea....I ratted you out to her.roflrofl
gimpyrobb
dumpsterlandingfromorbit!
27,786
796
Cincy Ohio
I'd still lean towards an incline. If it were filters, it prolly wouldn't act up in only fifth. Sometimes it looks flat when there is actually a hill.
