galeo7171
- 14
- 18
- Cumming, Ga
I know ATF fluid is supposed be used in the np208. I noticed a small leak coming front the transfer case skid plate and it was gear lube. I guess the police department that I got the truck from put the wrong stuff in. Should I get it out ASAP and replace it with ATF? I've also go to figure out where the leak is coming from, I do know its not the rear shaft seal.
