M1031 Generator control replacement!
wrenchturner6238
39
Beaver Oklahoma
So it is easy
Sure enough . Being it off you might as well get the count. I am pretty glad that you started this thread and we are making some head way. not really sure how finding the APECS 4500 will be it seems I looked at fleabay again and now there are only the 2 from china on there
deank
852
Inverness, Florida
I am not in a rush. This is a busy time for me right now. But I will keep looking. If the right one comes up I will get it.
wrenchturner6238
39
Beaver Oklahoma
Yeah I am not in a big hurry either but would like to compete. I have plenty of other projects to work on until I find a controller. I do not know if i have a computer that will work on the software
deank
852
Inverness, Florida
I have found a site to order the connectors with the sockets that plug into the controller and the socket removal tool. Will need the DTM06-SA and -SB.
Save1031s
MA
This seems to be convenient timing. I have been speaking with tech support at Parker Services. They are dealers for the APECS 4500. They have been incredibly helpful, but we are still trying to figure out the best path forward. I borrowed an oscilloscope from work and measured the signal coming from the magnetic pickup (MPU) on the PTO and the signal going to the actuator under the hood.
Here is what I found. When the generator is running at 60Hz with no load:
The MPU is putting out a signal of about 475Hz sine wave with the signal oscillation from +12V to -12V.
The actuator under the hood is a DYNA 8000 and needs a pulse width modulation signal (PWM). This signal for me was a 373 to 375 Hz square wave, duty cycle of 61%, and a voltage from -1V to +8V. The duty cycle changes the actuator position. so this could be a little different based on the linkage setup for each truck.
So far we have determined that the 475Hz signal from the MPU is a low frequency for a typical engine governing signal. We are looking at other controllers that may be more simple and require less programming than the APECS 4500, but the 475 Hz frequency is not common. typical ranges seem to be from 500 to 11,000Hz based on manuals I have read. Below are pictures of the signals. The DMM on top is the Hz and voltage coming from the generator.
wrenchturner6238
39
Beaver Oklahoma
Sounds like getting this worked out is going to get expensive. Makes one wonder if that someone like a dealer might be able to program the unit for us
deank
852
Inverness, Florida
Happy new year!
I have ordered the connectors, boots, wire, and terminal crimpers to build the harness. I will order the controller and the programming cable (USB) on Monday.
deank
852
Inverness, Florida
Connectors with pins, wedgelocks, and boots came in today. I have also ordered 16 guage pins for the actuator wires. The pin removal tool and the crimper have also arrived. I have ordered the controller and the interface cable from the Netherlands. Waiting for tracking info.
wrenchturner6238
39
Beaver Oklahoma
Alrighty! I now have a controller and the interface cable for programming. And! Another member has the calibration file we can use.
This is great I am glad you are able to find some people to help and the components needed. Are there pics of your truck on here somewhere?
