Rustyshackelford
- 14
- 18
- Tucson AZ
Those part numbers are not LED. Unless I missed something.Ok yes thanks guys. I do know how to find parts on ebay etc I just needed help with the LED part numbers so I could search the correct part. ZED nailed it and I have two new ones incoming from ebay.
| 12446845-1 | 24V. Amber/Diff. LED Assy/Shell |
| 12446845-2 | 24V. Red/Diff. LED Assy/Shell |
I have the same issue as well ... if you were able to resolve your issue would you mind sharing how you did it?Hi
I did some searching and even checked the Tm (which only seemed to cover incandescent) and I can’t find what I’m looking for. I have two dead LED side markers on my 1102 and I’m hoping you can direct me to a replacement. Here is a pic for reference.
check your ground and if that’s not the issue, there are lots of LED side marker lights on eBay. Just search hmmwv side marker.I have the same issue as well ... if you were able to resolve your issue would you mind sharing how you did it?
Thank you,
Brett W. Sabio
