DalekEngineer
- 4
- 8
- Castle rock wa
Okay I’ll just give that a shot then, thank you for the advice.
I was 99% sure that I put it back together properly. I knew the plunger could be installed into the butterfly clip backwards. Yet, I’m the idiot that floridianson is talking about from last week.I’m 99% sure I put it back together correctly, tomorrow I’m going to fill the fuel filters with fuel and see if she starts. If she does and I believe she will I will see if she still dies out of nowhere.
As for idiot I don't think so, you figured it out fast with no help.I was 99% sure that I put it back together properly. I knew the plunger could be installed into the butterfly clip backwards. Yet, I’m the idiot that floridianson is talking about from last week.
Then you need to look at your first fuel filter by the generator. It is suppose to be a fuel/water filter. Then clean out your fuel tank and add some water inhibiters/absorbers to the fuel. Or just dump the fuel and start fresh.I haven’t been able to test pressure but I found a tiny hole in the fuel tank that slowly drips so I put a bucket under it and the next morning I looked at it and the drip coming out of the tank was frozen so there was water in the fuel tank and I think that it might be dieing because the fuel gets stirred up and sucks up some water.
What Gimpyrobb said. Plus if you need NOS filters Gimpyrobb has them for real cheap.Best bet is to dump it, solder up the holes, then start fresh. Blow out the fuel lines and swap in all new filters.
Sometimes the truck can be setting at a slight angle and the water in the fuel settles in a corner. Then you only have to fix a small area. Of course there is the other side of the coin when your whole tank bottom has water setting on it ! Like yours appeared to do. Then your SOL !I hate to be the bearer of bad news, but if you have one pinhole in your tank you have a thousand. Start shopping for a new tank. I recently got one from White Owl. He’s awesome. If you clean the inside of your tank out thoroughly you’ll find the rest of the holes.
If you cannot find another tank, look into a older International truck tank like a 1600. Some of them had the foot step built into then, but you may be able to retrofit one in place and almost look original. Or build one to fit.I hate to be the bearer of bad news, but if you have one pinhole in your tank you have a thousand. Start shopping for a new tank. I recently got one from White Owl. He’s awesome. If you clean the inside of your tank out thoroughly you’ll find the rest of the holes.
