- 8,761
- 3,364
- 113
- Monrovia, Ca.
Well, Craig is kinda bummed about not getting the movie rental....so, he wants to start another project!
One of the M551's that are in the yard. He has 3, one is a totally stripped hull, one has the drive train but no interior or axles, the other, well, it was drive into place in the shop area a l o n g time ago. Drive train is complete, stops, steers, has the instruments, no ord stowage racks , drivers escape hatch or drivers seat. Should be easy enough to acquire some pieces from Irwin...he kinda has an "in" there and there are a mess of them on the range I guess. Since it's a driptroit, it will start VERY easy, even with low batteries! Gotta ck the trans and cooling system. One of the guys has already gone through the stuff inside and removed it and the stuff from the non stripped one on tank row to see what kinds of parts we have to work with and what we need. There will be pics, be patient! I can't wait!!! ![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
Took a bit to get it going, 1 injector was stuck in the no fuel position. Did a 180 from the parking spot and put it into the shop. There it got a traverse mechanisim, a temporary air filter, an escape hatch and a new barrel. W stole the bustle rack off the hull out in the front. Danny made new hinged covers for the battery and air filter compartments. Some body work was done, fixed a few panels and did some straightening and then a fresh coat of Cardinal Industrial, water based paint along with some new markings. The attached video is of the shake down run. After the track was given a chance to stretch it's legs, we found that we had no power. A quick once over and I found we had a fuel issue. The filter minder was sucked all the way to the red
