rossbart
- 50
- 18
- Waurika, Oklahoma
I just recently purchased two M817 5-Ton dump trucks. One is in excellent condition - the other probably a parts truck. Anyway, I'm having difficulty getting the dump to raise. I have checked and adjusted all of the external linkages from both the dump lever as well as the transmission driven pto box and hydraulic pump control box.
The bed will dump when empty (though you have to rev the engine up a little) but it will not raise even a light load. Also, I noticed that it will not "hold" and seems to just bleed down as soon as you move the control lever from "power up" to "hold". The fluid reservor is full and everything looks (externally) to be in great shape - no leaks, etc.. The control rod that goes up and down in the control valve body appears to be moving a full range of motion.
I have read the applicable manual pages and also searched the forums but still not sure what to do. I am suspicious that the control valve has something wrong in it and it's letting fluid bleed around the valve and, in effect, bypassing internally instead of sending adequate pressurized fluid into the hoses and cylinders. But, in looking at the exploded view of the control valve it doesn't appear that the valve rod (spool they call it, I think) has any replaceable or wear components like seals or O-rings?
I'm hoping that someone here has some experience with this. I could swap the assembly from my parts truck or I could take it off and just do some exporatory surgery and see if the bore or spool is worn or damaged but wish someone that knows more about it than me would lend their advice.
Thank You
Ross
Thank You
Ross
