- 86
- 33
- 18
- Chicopee Falls Massachusetts
just a question. will a M925 winch fit in the same place on a M818. from looking at 925 winch kinda looks the same. i think.
I figured something was different when i saw a hydraulic resivoir on the starboard side in back. So the input has an adapter for the hydrastic motor. Can a drive shaft be used instead.the winches are the same
but driven by hydraulic motor instead of drive shaft
example images below
9M-1070 | Hydraulic Motor Front Winch with Mounting Bracket with Driveshaft Coupling M939A M939A2
M939A1 and M939A2 Front Winch Hydraulic Motor with Mounting Bracket
NSN #: 4320-01-137-6293, 5340-01-084-1232, 2590-01-101-6712
Part #: 11669777, 12276904, 12276915
Price: $935.00
9M-1916 | Winch 20,000 lb Garwood PTO Winch Front Bumper Mounted with Hydraulic Motor M939A1 M939A2
NSN #: 2590-01-082-2644
Part #: 7412382-
Price: $1,275.00
.I figured something was different when i saw a hydraulic resivoir on the starboard side in back. So the input has an adapter for the hydrastic motor. Can a drive shaft be used instead.
Roger.
Nope. If you have a hydraulic powered winch - no - you can't power it with a driveshaft. Unless you can find the part that bolts in place on the winch itself...
