I know this was a long time ago and you probably covered it, but I’m unclear on a few steps.
your fuller bell housing bolted right to the motor bell housing and works because the input shaft is the right length to reach the pilot bearing, correct? Are all sae #2 bell housings the same length, or just bolt pattern? Do all sae #2 transmissions have the same length input and diameter shafts?
For the clutch:
It seems that you went with a twin disc clutch from the fuller, is this what you made an adapter for? My previous question about the shafts being the same leads me to ask whether or not the spicer clutch would work with the fuller trans. If not, why not?
I think this covers all my questions, sorry to bombard an old thread like that but you’ve done it before so I figured I’d ask.
thanks in advance
