ger84
- 26
- 18
- Clinton, NJ
Hi all- I have a M925a2 . Been messing with the truck for years and its been fun. I have used the winch for stupid things and pulling cars from out of ditches and always worked with out a problem. I was "playing" and was trying to use my winch to pull a tree down when cutting it. Noticed that when winching the winch stopped turning... its like it was maxed out (i was expecting to either break a sheer pin or cable before the winch just stopped moving) and the truck wasn't pulled into the tree like I expected. either I did win in the end vs the tree however am I missing something. That winch should have either dragged the truck to the tree or pulled the tree down! The truck wasn't anchored other than the brakes were on. I was on grass! I checked the TM's about procedure of using the winch and think I did it right... its either in gear or not for the winch to spin or not spin and then inside the truck the handle engages or disengages the winch. I left it in neutral and also put in gear with no difference and yes I did give it some throttle so the winch would spin... any insight would be appreciated... I will see if I have video clip I can put on this weekend.
