War Time Finds
- 0
- 0
- Bells Texas
My M931A2 trys to kill the running motor if I move my transfer case lever from high to low then put the Allison trans in gear, if I play with the transfer case lever, up and down for a few minutes and then go into reverse, it does' not stall and I can then go forward. It does this several times, killing the motor each time till I get the lever in the correct spot to by pass????. It's like something in the transfer case lever tells the transmission to by pass the torque converter and kills the motor.
