roadagent
- 0
- 1
- Keystone, SD
I was running down the road with plenty power then nothing. Came to a stop. Truck will idle at 450/500 RPMs. Press down on throttle and no increase in rpm. Changed filter. Bypassed tank and selector valve by hooking onto fuel canister with 5 psi inline pump running off of fresh 5 gallon bucket. System pressurized easily. Started right up. Same problem of no throttle. Switched back to stock system no change. Looked for fuel pump filter. Either missing or stuck nothing came out when I removed Allen head plug with o-ring on it. Any ideas?
