gokeeper
- 4
- 3
- Moville, iowa
I just picked up my first M998 and got her home. I noticed the wait to start light just barely flashed and does not stay on. I downloaded all of the TM and started reading all of the threads on these vehicles over the last several days. Been inspecting each parts and checking cleaning grounds, preparing to do normal maintenance etc.
I found the Alternator is not charging, found that it had been replaced somewhat recently. I am assuming a cheap aftermarket Alternator please take a look at the pictures. Can anyone Identify the alternator? In my troubleshooting there is 0 voltage at the alternator since the voltage is fed through the EESS and with the lack of wait light activation I am assuming a bad EESS (Will troubleshoot that more tonight).
I assume the last owner knew it wasn't charging and replaced the Alternator which also didn't work. Main question is has anyone seen this alternator? Second question wire 568 is not connected to the alternator but believe it should be at the top port but without any information on the alternator I cant tell. Second if the EESS is bad can I bypass the EESS just on the batter voltage side to get the alternator charging to test it while I await parts? Looking at the diagrams its possible just questioning weather one should?
