High Water
- 9
- 8
ahhh.... all the information helps. could not tell by pics it was for square hole. What does this hold?Thanks so much for those links. I thought I had covered the Fastenal website but you found one that I didn't. Unfortunately, I don't see any that fit correctly; too big, too small, etc.
Here is another site with many clips but no luck there either: https://www.clipsandfasteners.com/upholstery-hardware-s/825.htm
I might have to resrt to drilling out the square holes to round and using nut rivets (rivnuts). I really want to avoid that.
Thanks again that first plastic one might work in some of the places. I need to measure the square holes again, I did it once but have misplaced it. It seems like it was 4mmx7mm. I am not where my truck is at the moment.ahhh.... all the information helps. could not tell by pics it was for square hole. What does this hold?
rivnut is better but maybe overkill for what ever it is your fastening down.
Thanks for the tip! I am okay with plastic retainers on things like molding but for the hand grips above the door, I will rivnut them.I found some plaststic clips at the auto store . I think the clips are for a Huyndi or somethinng like that. As for the screws I use #10 stainless steel.
