maybe a stupid question but.
HDN
5,790
Finger Lakes Region, NY
All the videos I've seen have had a spring and a metal disk in the valve. Mine does not have them. So I was wondering if my valves have been neutered
Can you please share the video links? I can take a look at them and compare them to the TM.
I haven't had any wheel valves apart on my truck as I decided to leave them off after I replaced the tires.
spectra3279
105
33
western Ky
they were not of m35's. they were of lmtv's but the wheel valves look the same.
some of them
HDN
5,790
some of them
Thanks for sharing those. The wheel valves look the same except for the fact they are FMTV wheel valves with different components in them :p The FMTV is a different truck with different manufacturers. I'm pretty sure CM Automotive didn't design the CTIS for the FMTV - maybe it was Meritor instead?
Anyway, the M35A3 valves are designed for the M35A3. They do work as designed, as I know at least @glcaines has a functioning stock CTIS on his A3. Go by the M35A3 TMs. They describe the parts of the truck as they were built.
Be sure to have M35A2 manuals available too as they cover parts of the truck that were unchanged in the A3 remanufacture.
spectra3279
105
33
western Ky
ive downloaded the TM's. plan on printing out the sections as i need them and keep them in a binder for shop use.
i realize the fmtv was done by a different company. but was unsure if they had the springs or not. like i said was afraid mine had been neutered.
  • Like
Reactions: HDN
HDN
5,790
Here's the valve diagram for the M35A3:
There is supposed to be a spring in there (part #14 toward the left side of the image). I take it you've had your valves apart and the springs are missing? I'm not aware of any manufacturing differences with the valves where the spring could be omitted, but we're talking about the DoD and their stuff is made by the lowest bidder 😬 I'd think a change like that would be noted in a TM.
spectra3279
105
33
western Ky
mine seem to be completely. from what i can tell mine do not have parts 14, part 6, part 15 and part 6. thats what i can tell just by removing the cover part 8. ill have to pull one all the way off and disassemble to see. they do not leak though.
HDN
5,790
sure. it will be a couple of days before i will have time to pull one off and get pictures
You can leave it on the wheel too if you'd like. I think the A3 valves are distinct enough from other valves that we should be able to tell whether they're something else while they're still mounted.
