metalworker393
- 33
- 28
- Jackson NJ
Hello and how are you all doing. Have a question I could find the answer to in the TM's . I'm doing the PMs on my 002a ,changed the oil and moving to the fuel system. P1 and P2 are working well. I cleaned the screens in the bottom of the pumps last year and haven't had an issue. My question pertains to the auxillary pump. The pump is barely clicking when turned on. It worked well several years ago when I was without power during Sandy refueling from a 55 gallon barrel.
I would like to know how much voltage should I see at the connector for the solenoid ? I have a Fluke meter to check it, don't know what it should be. Want to also make sure the solenoid isn't malfunctioning. After work today, I'm going to remove the bottom cover and check the filter, then remove the solenoid valve and see if it pumps. The machine has a little over 1200 hours on it, and, it may be a bad pump as well. I don't have a spare pump so I ordered 1 yesterday. It would be good to stock 1 anyway.
Thanks, metalworker393
