- 1,207
- 113
- Athens, Ga.
So, I'm rebuilding an MEP-003A genset and an M116A2 trailer.
I am in the process of going through the fuel system and am running into the typical issues. Lack of maintenance, corrosion, sludge, etc.
I am soaking the filter canisters and components in CLR and getting good results. The tank was full of sludge and I pressure washed it this morning in order to get the big chunks out before soaking it in CLR and I found that the tank is toast. Multiple pinholes in the bottom.
I don't think it's worth it to try and patch this tank. I'm afraid it needs an entirely new bottom section.
So I need a replacement tank. I see Green Mountain Generators has a new aluminum tank, but it's for an 002A and only holds 6 gallons. I don't really wanna' do that, I'd like to keep my 12 gallon fuel tank.
Does anyone have a good used tank available?
