Mep 003a help
kipman
15
Lancaster Ohio
New to my brother, MEP 003A, has a new IP, have fuel to the injectors, bleed all the air out, it shows no smoke at all, wants to fire on ether, builds 28 psi of oil pressure when cranking, any Ideas?
doghead
4 Star General /Moderator
1,196
NY
IP timing?
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
Kip, I'll call you later today and we'll talk about what's going on.
We'll get it going for ya :grd:
AceHigh
32
Lake City FL
Good luck on it. Probably something simple I hope.
I spent yesterday running wire and finally after several months ran our shop on it. Even the big heat pump. Ran like a champ.
Carl_in_NH
Wilton NH
Hello, Kip. Just got your PM; if I can help let me know, but I suspect Tom has got you covered.
You've got fuel to the injectors - but at what pressure? If it's not making enough pressure to open the injectors, it would act as you mention; could be a stuck or only partially returning high pressure plunger causing the trouble. They get gummed up from time to time.
Otherwise, recheck timing as suggested - use the alternate method (PC flywheel mark and fuel flow) of pump timing from the TM or AMBAC pump manual to make certain they got the correct button installed when they changed out the pump.
Make certain you're on the correct TDC for #1 as well by removing the valve cover and making certain both valves are closed.
