MEP-501 Conversion & Modified Fuel System
rustystud
3,487
Woodinville, Washington
Well I finally got tired of my MEP-501 and decided to convert it to 240 Volts AC, (2KW) . Making it a MEP-531 basically.
I also changed out the fuel system. I don't know about all you guys out there running the small Yanmar engines, but every time I replace the fuel filter it is a pain in the butt to get the machine to run again due to air in the lines.
So I installed a 24 volt Faucet pump along with new "PTFE stainless steel" lines.
Now I just hit the start button and BAM ! She's up and running. There is also only two rubber lines to worry about now. All the rest are PTFE stainless. I installed a switch valve so I can use either the small factory tank or get fuel from my large tank which will be mounted in my M105 trailer later for the "Great Alaskan Adventure" . The switch right now doesn't handle the return fuel, but a 6 port switch is on order.
Light in the Dark
7,271
MA
Good work. One of these days I'll finally get around to the genhead swap on the BAPU.
rustystud
3,487
Well I found out why my MEP-501 was being such a little ass all the time I owned it. There was some loose wires from the engine side in the electrical panel. I just "assumed" it was a fuel problem all along. Turns out the crimps where not holding and the wires where coming out, even though they used heat shrink tube on them.
This is why I am such an out spoken advocate for "soldering" the connectors. After I finish converting the electrical panel, I will go and solder all the connections. I have never had a problem after soldering a connection on a vehicle or anything else.
Here was one of the worst offenders. I re-crimped it for now.
What is so annoying is I would never had found this problem unless I had taken the wire loom apart. It was buried under the other wires and wire-tied together.
Remember this was a "factory" crimp too ! A crimp made with the "proper" tool, and it still failed.
CallMeColt
1,781
Wilson County, Texas
I like what you did with the fuel lines. Great idea.
When I did this, I had a problem with the generator not matching up quite like it should have on the crank shaft & had the machine a little bit off the mounting plate. What generator head did you use?
