kipman
- 15
- 38
- Lancaster Ohio
I have read on here somewhere that a 701A will not put out 240V in single phase, but there is a fix, can not seem to be able to find the thread, anybody remember that one?
Right on, Ike. Each machine must be inspected to see how it is wired in order to fully answer the question.Well that is a complicated one. It will put out 240V single phase, what it may not put out is 120/240V split single phase (common household power), I say may not as it has been noted by multiple people that both the wiring diagram in the manual and the one inside the top cover have mistakes, also out of a sample of several MEP-701a's and MEP-016b's it seems most are wired to output 120/240V single phase when the voltage selector was set to 240V single phase. So before you go trying to add an L0 jumper it is best to measure the output lugs on your unit in 240V single phase mode. (note the jumper is needed to get 120/240V single phase on MEP-016A's, C's and D's, but maybe not on B's and E's)
Ike
