dkozma
- 0
- 1
- warwick/new york
Evening All,
This post follows up on a crank but no start issue that I posted about a month ago.
Followed the TM troubleshooting guide. Found that fuel was flowing but not under pressure.
Started reading posts specific to the injector pumps.
Pulled one injector. Was frozen. Able to free it up without disassembly. Great, right?
Except that when I removed the said injector, a small spring with a slotted plug came out with it,
at least it was laying next to the pump opening. Glad it didn't fall in. Can't find it in any diagram.
Don't want to pull the other pump until this one is back in. Am attaching a photo. It's to the left of the pump.
The bolt with the yellow dot is for holding the steel fuel line in place. (Had to remove it to move the
line over.) Any help on re-assembly? The small spring has me baffled.
Note: photo coming, have to re format image
