Now I understand.
Well, like I told you in post # 11, you can remove the flywheel and rotor, from the engine, without removing the Drive Disc, (red plate) from the Flywheel. That would make this job easier. If all you want to do is change motors, then that's what I would do. Separate the flywheel from the engine. Check the main bearing, (item 20) to make sure it's still good, and then put the main gen back together again, and attach it to the new engine.
Or, if you just have to remove the drive plate from flywheel:
Have you tried removing the bearing, (item 20) and then whooping on the shaft with your dead weight hammer? And (even better) after removing the bearing, I would remove the exciter rotor, (item 23). That way you have lots of shaft to whoop on, without fear of doing any damage. Use caution to ensure the rotor does not fall and get screwed up. After all this hassle, you would probably flip out and jump off the roof.
I have never in 28 years of repairing gen sets, seen a drive plate not separate from the flywheel. There is absolutely no reason that they should not come apart. Since there is no mechanical reason, then there can only be:
1. Someone has used some kind of adhesive, or:
2. The drive plate is not the right one. The drive plate for the 400 hertz is a bit bigger, I think. But I am going from memory, of seeing one about ten years ago. This cant be a 400 hertz main gen, cause the flywheel is too large, hence, its a 60 hertz main gen. There is no earthly reason these two parts should not come apart after removing all 5 bolts, (item 16) from the drive plate. None.
After looking at this picture for the 500th time, I wonder, if it's the paint? I have never seen a drive plate painted. Never. Always bare metal. Could the paint have something to do with the problem? You said the engine was bad. Did it overheat? Run with little or no oil? I sure wish I was there. This sounds interesting. But it ain't getting your gen set fixed.
Right now, if you just have to separate the drive plate from the flywheel, the I would follow the suggestions listed above. If you don't want to do that, then just remove the flywheel from the engine. It's the fastest way, with the least possibility of damaging something. If you do remove the flywheel from the engine, use new bolts to put it back together. Grade 9, (I think). Torque them up by the book, dry, not wet.
Please close the loop on this. I am very interested.
