MEP-804A Voltage issues.
Crankcase440
21
New Jersey
I had purchased a MEP-804A from an auction and got it running. First issue was under current, only showing 50 volts and 50 volts at the convenience receptacle. So I had purchased and swapped in a new voltage regulator and now I have overvoltage. The hertz is reading correct and the potentiometer seems to be working for the herzt and I can hear the pitch change of the engine ram. The voltage gage is pinned at 500 volts and nothing changes that. This unit doesn't have the fuse mod (I read about that in another thread) and I am not that familiar with genset units so any help would be appreciated.
21,238
First thing to do is to download the TM for your genset.
Then a little reading should help...
kloppk
4,343
NC
Be aware the 804As were built with two different AC Voltage Regulation systems.
Parts cannot be mixed between the systems.
One was a "TRC" system and the other is a "LIBBY" system.
There are 4 parts of each system that are unique to TRC and LIBBY.
They are:
- A1 AC Voltage Regulator
- T1 Transformer
- Front Panel AC Adjust Potentiometer R1
- Resistor R16 on the back of the 50/60 Hz switch
Crankcase440
21
New Jersey
Thank you, I had gone through the manuals ( I even purchased the printed manuals for the unit) especially the troubleshooting sections. I still not sure if I am dealing with a voltage regulator issue or if it is a damaged winding in the generator head. My knowledge of generator heads is rather
They are:
- T1 Transformer
Yes I read that on another thread. I purchased another LIBBY Voltage regulator same model number (which may also be defective). Does anyone know if the aftermarket voltage regulators from Green Mountain Generator is compatible with all units? I will double check the other components to make sure one isn't compatible.
Guyfang
28,632
Burgkunstadt, Germany
Just because you took a Libby out of your set to try and fix it, doesn't mean its supposed to have a Libby. You need to check all the other components, to make sure they ALL match.
If green mountain is selling VR's, and they are original military VR's, and they match the 3 other components in the set, then yes, they will work.
Is S-12 in the 60 hertz position?
Compare the TM date, and if it has Changes, to the TM's in our TM forum. The latest TM's with changes are in the TM forum.
Crankcase440
21
New Jersey
You are absolutely right, I will check the other components to see if they are Libby compatible as there is no telling what happened prior to me purchasing the unit so swapping like for like may not be the answer.
Yes S-12 is in the 60 hertz position.
Green Mountain Generator looks like they manufacture their own version of the voltage regulators, but it eliminates the transformer and only will output 60 hertz. So I did not want to take the chance with the aftermarket if I could get what I believed was original equipment for the unit. But I will definitely go check out the other components for compatibility.
LuckeyD
776
Vilseck, Germany
Good day: Please do not start the gen anymore until you check out the regulator TR1 and AC Voltage adjust combinations. I attached a sheet that also allows you the check the main gen as it is not rated at 500+ VAC for very long before it kinda sorta makes lots of black wires inside. Taked out of the manuals It applies to.
1. Check the data plate on that main gen. It should indicate a 50/60HZ main gen, NOT a 400 HZ main gen. The data plate for the gen should indicate 804 and not a 814. Had that one in a Patriot outfit performed by their contracted maintenance. Acted like what you indicate. Then they called me as I was on my way to a war zone.
2. Libby combo, also found on the attached sheet and the above PS Mag article several times, the regulator is usually green and has Libby printed in it saying it is a 50/6ß HZ regulator; The TR1 has black Terminal boards for connections, and the Volt ADJ is only 10K ohms. Always change with the regulator I recommend. Then test the Volt ADJ.
TRC will be black and say TRC on it, the TR1 transformer only has loops to make connections no terminal boards, and the Volt ADJ is 20K ohms. a 15K ohm Pot is used on 400 Hz gens. I used a Milliohm meter to test main gens as the usual DMM is not sensitive enough. Some folks use a whetstone bridge.
You may want to check your TR-1 transformer connections as going from 50 to over 500V is a little odd no matter what combo you use.
Crankcase440
21
New Jersey
Thank you for the information. The generator shut down right away after the overvoltage fault came on (I wasn't running it with the battle short). Yes I confirmed it is a 804A not the 814A. The hertz was right on but it went from under to over voltage with the change of a voltage regulator. I will check and clean the transformer terminals, but there is the possibility the second voltage regulator is malfunctioning as well. Thank you for the information.
Crankcase440
21
New Jersey
I got a new voltage regulator installed and it is now making the correct voltage. Now it seems like the AC interrupter contactor is not working properly. I am not hearing a click and when I looked at the troubleshooting guide it said refer to higher manual. I looked through and not sure which one it is referring to. Not sure if I should strat with the actual contactor and clean it or the relay. This unit had been sitting unused for awhile from the looks of it so it may just be some corrosion in the contactor but I wasn't sure of any other testing procedures.
21,238
Definitely need to spray down the contacts with contact cleaner. Then manually exercise the contacts, then spray them again, and maybe even one more time for the sake of doing it...
Guyfang
28,632
Well if your going to clean it, that means take it out. As long as you have it out, test it before and after cleaning.
Take the K1 over to your batteries. Take two wires and hook them to the K1-X and K1-Y terminals. Then touch the other ends of the wires to 24 VDC, (Your two batteries connected in series. If the K1 is good and works, you will hear a clunk. Have someone else measure for ohm between A1-A2, B1-B2 and C1-C2. You should get continuity. Remove continuity and there should be no continuity between the A, B and C contacts. Easy test.
Crankcase440
21
New Jersey
Thank you, I will do that. I appreciate the diagram as well.
21,238
What is best used to lubricate the mechanism in the contactor ? Dielectric grease? It was tricky to get out and I certainly don't want to have it corroded again anytime soon.
There is a spray version of dielectric cleaner.
Can't remember the name of the stuff... :-(
Crankcase440
21
New Jersey
I used the CRC QD electronic cleaner to clean everything up, so now I want to lubricate it and give it a light bit of corrosion protection. Google results have been contradicting at best. Wasn't sure if there was a spec I should be following. This looks like it was a problem before as there was a scorch mark from arcing inside the cover. Looks like is partially got hung up at some point and didn't fully close the contactors.
21,238
Okay then, yes. Dielectric grease put into the contacts should be the trick.
Don't glob it in there, just coat it and you should be good to go!
Crankcase440
21
New Jersey
Thank you sir! One other question, when I get it back together and reinstalled will the contactor close with the power on but not running/energized when I hit the AC interrupter switch? I jumped it to 24v at the battery terminal and it appears to close but wasn't sure if would without the unit running.
