MEP-804B Missing Gauges
uscgmatt
14
Denmark, Maine
The 4th guage is the volt meter. As for the source of them, the parts manual will give you the manufacture and part number. The ones on my 2 sets are pretty inaccurate so after market might be better. There was a mwo to change the rear tires from dual ndt's to singles.
WildernessJeep
92
Huntsville, Texas
So do you think it came with duals tires and was later changed to singles, or was this trailer always a single tire axle? I'd prefer the duals, if it would be as easy as buying two more rims. I want to load it down with fuel, and don't want to overload the tires.
R
Guyfang
28,632
Burgkunstadt, Germany
R
No, it did not come with duels. That's the way it was made. You will need more then lug nuts and thimbles. The axle is different also.
Would also suggest you down load the TM's, if you haven't already. Most of the gauges should be available, if you look for them by part number and NSN.
Guyfang
28,632
Just looked at your pictures again. I think you are missing more then just gauges. R1 is gone also. Take pictures of the inside of the control panel. You may be a bit short of stuff there also.
98G
Former SSG
5,080
Going the other way from duals to singles all you have to change is thimble removal and a lug nut change. What's different here?
I readily admit I might be missing something. Enlighten me...
155mm
Chief and Indian
515
Guymon, OK
The rim offset for the dual is too much to go from singles to duals. Duals to singles is no problem. The dual wheel rubs on the springs before you get the thimble on.
  • Like
Reactions: 98G
Guyfang
28,632
I was told by a TACOM guy back in 2009? that the axle was different. Just now, I went and looked at the parts TM. There are a few different part numbers between the two styles. But the axle is the same, between the dual and super single.
  • Like
Reactions: 98G
