My backup to my backup generator is a "Vanguard" 16HP Briggs&Stratton 10KW unit (actually only 7KW) and it runs on propane from our 500 gallon tank.I would convert a gas engine to propane before I mess with cng. Very limited around here on cng stations
I didn't know that about the stationary application. Thanks Keith for the Illumination ! (get it, lights, generator ? well I thought it was funny !)For stationary applications, you don't need to compress the natural gas, making it far more economical than compressed. This is what makes CNG expensive.
Good point !!! I wasn't even thinking about that when I responded to the CNG option. I have a propane generator since I have a 500 gallon tank ( back-up for my back-up ), but I always go to my diesel MEP units when the power go's out ! As far as long term storing of fuels go, propane is "king", but diesel is right there behind it.The gotcha in running your generator on municipal low-pressure natural gas is that you have to have constant availability of municipal low pressure natural gas. Basically, you're protecting your dwelling against an outage of a utility supply by depending on a different utility supply.
It is generally harder to disrupt municipal natural gas than electricity, but I've seen both go out if things are bad enough, sometimes for days. (Hurricane Fran in Raleigh did disrupt some Nat gas supplies. Whether or not you had gas the morning after depended on random luck in your choice of neighborhoods).
I'd stick with fuel stored on premises for that reason. Propane is good if you think through the use scenario carefully. I stuck with diesel because of the ease of getting more after a disaster versus getting a propane truck up the hill on the narrow, tree-lined road to refill the buried tank.
